General Relay help
General Relay help
ozfish
Got a possible relay problem with the Ulysse. Its a 1999 2.0 EL Petrol.
The interior lights have packed up when the doors open. I have checked the lights themself as I know they play up and all connections seem fine. The map reading lights work fine.
The fuse is fine and the door contacts are working as the front lower door lights come on and the 'open doors' display by the mirror shows each door as open when tested.
I'm thinking that the time delay relay must be faulty but dont know as to where it is or colour/postion it is hidden!
Any suggestions would be great, as its another job to do on the Ulysse after the recent few, new offside driveshaft / new pads and discs / new nearside outer cv boot......
Still find it a great car when it going though!!
Thanks,
Oz.
i've got the same problem with my car, but on mine it's the centre switch in the roof panel that is causing the problem, if i wiggle the switch around with the doors open it works, their is a brass contact behind the switch that seems to weaken with use :(
