Technical Refurbished, 5 speed manual gearbox. Type (C514.5 ) £485
Fortunes Gate
CORNWALL
PLEASE READ IN FULL
I'm a genuine person with a genuine sale of a Fully Refurbished Manual 5 Speed Gearbox.. C514.5
Casing number 55231434..
So why would you buy a used / pre-owned gearbox when you can have a fully refurbished gearbox for sometimes less money!!
I take pride in all of the work that's put into the rebuilding of my gearboxes to make sure that you're getting the best value.
THE GEARBOX IS ALSO AVAILABLE FOR COLLECTION,
AND THEN YOU CAN SEE MY SET UP AS I HAVE NOTHING HIDE.!!!
Please contact me in the first instance to discuss your requirements.
Fully Reconditioned 5 Speed Manual Gearbox Will Fit The Following.
Fiat 500 1.2cc (312) from 2007 on
Fiat punto 111 (199)
Fiat panda (319)
Ford Ka Mk 2 - 1.2cc from 2008 / 2016
Alf romeo mito (955)
Chrysler ypsilon 1.2
5 Speed, ( C514.5 )
Manual Gearbox
With a 12 month or 12000 mile warranty.
Terms and conditions apply
Please ask.
All my gearboxes are fully striped, thoroughly cleaned and checked and checked again until i am totally happy with the results.
All gears, shafts, selectors and other components are examined, rigorously tested, and checked for quality, durability and longevity, Even down to the clutch fork bushes being replaced.
And then this is where i start to do the rebuilding of the gearbox. After thoroughly inspecting the gear train and replacing worn out components.
The gearbox casing is then soda blasted along with other components to remove all the dirt and grime, and then it's given a coat of paint ready for the built up
Using up-rated bearings, and new oil seals.
The top selector housing is striped and checked for uneven wear and new oil seals replaced.
The gearbox will be delivered in a wooden crate, and then this is reused for return delivery,
Or you can come and collect the gearbox from me and then you can see that I am a person who takes pride in their work.
Be very cautious of much cheaper gearboxes that are on offer, as i have come across gearboxes that have just been painted to look like a reconditioned one.
The gearbox is sold on an exchange basis, there is a deposit required but this is refundable when I have your old gearbox back.
Without any holes or damage to the casing in exchange for my reconditioned unit.
SO WHAT DO YOU GET
Fully reconditioned 5 speed manual gearbox complete with a full set of bearings and oil seals..
Please any Q's, then do not hesitate to contact me.
The gearbox will be delivered with UPS direct,,. Or other courier in a crate to which the return exchange gearbox should be drained of all the oil and sent back to me securely in the crate
Please let me have your vehicle registration number so i can check compatibility as mistakes cost you and me money
Thank you
Dave
07931 - 194563
Please purchase with confidence, and be very wary of unscrupulous people as they are out there!!!
£485.00 Cash / Bank transfer
Mainland UK delivery only.
Model
500, Punto, Panda 1.2
Year
2007
Mileage
It all looks nice and clean.
I would suggest you put some proper details of exactly who you are and where you are based, maybe a link to a web site. May be some info on your background. Are ypou a business or a retired engineer. etc. Without this however tempting its a risk I wouldnt take when I can use a local specialist with a cast irn warranty. Forgive me if I am being pedantic, no disrepect is intended.
I would suggest you put some proper details of exactly who you are and where you are based, maybe a link to a web site. May be some info on your background. Are ypou a business or a retired engineer. etc. Without this however tempting its a risk I wouldnt take when I can use a local specialist with a cast irn warranty. Forgive me if I am being pedantic, no disrespect is intended.
Thanks for your message and yes you are right, I will rearrange my details and no hurt feelings I'm not very good at putting advertising together
Regards Dave
Regards Dave
Great. The price should attract plenty of customers. If you can do gear boxes there are clearly lots of possible customers here maybe to order on varoius Fiats.
Yeah and thanks for your message I deeply appreciate your thoughts, and I will get the perfect message out there to all, I'm a dedicated Ex Tech and was in the business for many years, and just want to offer the perfect package
Regards Dave.
