Paul Simon
First of all, a question. Should the piston be able to release itself from the caliper when under pressure from a pressure bleeding kit, or does it indicate a faulty piston seal?
I was in the process of bleeding the brakes, and took the front wheel off, and noticed that the disc was very stiff to turn, Without disconnecting the pressure bleeder, I undid the caliper bottom bolt, and removed the pads to clean them. A few minutes later, the piston popped out and dumped fluid on the floor (I immediately released the pressure and clamped the hydraulic caliper hose, and refilled the reservoir, which hadn't gone too disastrously low luckily). Luckily, the pads were out of the way.
If there's nothing wrong with the piston seal (still in the caliper), how do I reinstate the piston? Does the seal need to be removed first?
