- Joined
- Oct 26, 2012
- Messages
- 20
- Points
- 10
Hi Every One, not sure if this is best place to post this but has any used Redex? or any other product like this?
are they any good?
are they any good?
Contains other stuff as well as paraffin, solvents to dissolve any fuel deposits.
Petrol, if left will evaporate, but not all of it evaporates, leaving some of its components as sticky deposits. Any vehicle used infrequently, or for short journeys, can suffer from these deposits restricting fuel flow. When we had carburettors, it was often necessary to dismantle and clean these to allow them to again perform as intended, as anyone with a classic car now.
Petrol, if left will evaporate, but not all of it evaporates, leaving some of its components as sticky deposits. Any vehicle used infrequently, or for short journeys, can suffer from these deposits restricting fuel flow. When we had carburettors, it was often necessary to dismantle and clean these to allow them to again perform as intended, as anyone with a classic car now. Not everyone uses their car every day and for reasonable mileages.
To remove fuel deposits, other solvents are required. Redex, and similar products dissolve these back into the fuel. Using it occasionally will help prolong the life of injectors, many of which are replaced because the cost of cleaning them is significantly more than new ones. This applies to petrol and diesel. Most fuels these days contain additives to reduce deposits, and using expensive stuff will reduce the possibility of such deposits and help shift stuff already there, but they will all leave goo if left to dry up. Sadly the expensive fuels won't pay for themselves as any gain is less than the extra expense.
If anyone buys a car that's had little use, a shot of redex or other injector cleaner may do a lot of good, it will not do any harm. Using it regularly will just waste money.
