Red Warning Light
Red Warning Light
P
Paul McD
I have a red warning light coming on when im driving. It is a Red Exclamation Mark with Brackets round it, (!) It comes on when my handbreak is on, but when im driving it comes on whenever I turn the steering wheel to the left! It doesnt come on when i turn right for some bizzare reason.
Bought the car second hand, therefore I dont have a Manual.
Can anyone help??
first port of call would be to check the break fluid and pads / discs
Andy_sx
Warning
My breaks are squealing right enough, and my father in law said that I should change them, you think thats why the light is coming on then?
the light is also a wear indicator, so yes, id give them a look over with the view to changing them
Andy_sx
its your brake pad light
best to change them asap
dotn think about leaving them for a bit
as they will scrape really badly and you will hear a really bad noise
change the pds when the light is on
if you dont you coudl affect the brake disc itself if you leave it
fittign and pads tops £30-£40
It is NOT the pad warning light, that is a different light.
The handbrake light also indicates low fluid level.
You have low brake fluid level.
Going to Change the pads at the weekend, father in law says he can help me do that ourselves.
Still cant understand why it only comes on when i turn steering wheel to the left.
Checked all fluids and they seem to be between max & min levels.
accept y pologies
you meant this one
bmber 8
yes it is correct do what he said above
again sorry m8 for the confusion
The brake fluid will move around when turning or accelerating/braking hard and in turn will trigger the sensor that brings up the light!
Top up the brake fluid and check that it isn't leaking anywhere!
personally i wouldnt advise just topping up the break fluid, id check the pads aswell, as if you just top up the fluid and your pads need replacing you will be getting false readings and i wouldnt want plenty of fluid and shot pads personally
give the break system and good once over and take it from there
Andy_sx
Definatly the Brake Fluid you need Dot4! It happend to me about a month ago!
S
2
545
Dark Lurker
P
2
416
Dark Lurker
J
1
705
Dark Lurker
T
13
963
A
5
713
Darren
