Technical  rear wiper pipe
London
hello there
you all know that the pipe for the rear washer comes from a hole in the roof at the back.
mine this pipe is loose and it doesn;t seem to connect with anything when i try to push it inside.would anybodey know if the whole pipe is comming through the roof from the front of the car?do i haxe to take off the roof upholstery?
the pipe runs along the roof, down the front (behind the passinger side windscreen cover) and down behind the dash to a grommet behind the thick carpet near the fuse box. Its there they usually break or get creased - and fill your passenger footwell with water :mad: Theres quite alot of slack on the pipe (well on mine anyway).
Just wondering are you wanting to replace the pipe, if, so, is it possible to glue or attach your new pipe to the old one and just pull it through?
