General Rear Wiper Blade
Gaz999
England UK
I have searched so much for a rear wiper blade for a fiat punto mk1
and i cant find any i need a 14" roughly .. rear fiat punto wiper does anyone know where i can buy one of these fairly cheap ish!! :)
If they are the plastic moulded thing like on the mk2 then fiat is pretty much the only place to go.
Though last time I needed one I spent £2 at local car parts store for some wiper refils
Can't see the problem here if the old blade is still in tact. As pointed out just a case of fitting an infill cut to size. Any motor factor will have refills. Poundland do blades. Just cut the infill.
The reason you can't find any is probably because nobody buys them anymore because they just use the middle, goodish bit of a used front wiper:)
