Number plate lights - spies!
I'm sure others have been here before me
Just before we went off to Ireland in the Stilo I had a front headlight bulb go (n/s front) which was in itself a pain the backside to change
but just after that I started to get the warning about number plate lights..... which more often than not went out a few seconds after the car started.
In my changeover day yesterday (from dayshifts to nights) I decided to have a squint at the number plate lights and see what was what. Now having had several Italian cars I knew this would be fun, but little prepared me for what I found..... sadly I didn't have my camera to hand so you'll have to rely on my somewhat dodgy descriptions of what I found.
The mounting screws were shot, managed to get 3 out of 4 out successfully (with much careful 'tweaking') and they went straight in the bin, I thought that only Lancia put stupid rusty screws into such fitments but seems that it's common across the family! Worse than useless unless you live somewhere nice and dry and warm.
Lamps came out easy enough (interesting fitment, nice thinking), but the amount of corrosion that was in there was truly astonishing
How on earth the lights were getting any power at all was a miracle.
I cleaned the contacts inside with some electrical cleaner and when that ran out cleaned up the oversrpay, dried the inside as best I could and liberally sprayed in some WD40. The holding screw mounts were extremely mucky, gave them a damn good clean and applied liberal amounts of vaseline to ensure that future removals will go more easily.
The lights themselves..... well they were incredibly filthy as well as corroded to hell. The bulbs were intact and cleaned up OK. Managed to break one of the light connections (thank God for superglue
) but they cleaned up OK and a bit of wire wool and an emery board (thanks to the Mrs) ensured the contacts came up pretty clean.
This all took much longer than I had originally anticipated and with a 45 minute drive to work looming the whole lot got bunged back in sharpish-like. I would have preferred to have drilled out the broken screw but time was against me. I used (you'll like this) screws from a washing machine to replace the dodgy Fiat ones..... when I had Lancias I discovered the virtues of sourcing quality screws and bolts from unusual sources. Top quality screws in this instance from a Hotpoint (although other sources are available
), which will
not rust into place
Moment of truth.... turned the lights on and alarm city..... and no rear number plate lights. Bar steward :bang: Took 'em out again, re-cleaned the contacts and added some vaseline to help prevent future corrosion. Turned lights on.... nothing
Applied old Lancia logic and thumped the lights hard. Bingo! They live!
Now have brighter number plate lights than I can ever remember on the Stilo. Did get the dash alarm briefly this morning when I left work but went out in a second...
Fingers crossed they'll continue to work OK. However, still have to drill out one broken screw and replace it. This is a precautionary tale, if you've had this 'spy' then I'd urge you to have a look at the lights and consider having a 'play' like I have done...... certainly replace those damn silly screws for something more meaningful :idea:
Have fun
