Take the lights out... put them in a dry and warm place to get rid of any moisture, then use some silicone/epoxy/tape to seal all the holes through wich the moisture gets in.
Thanks, but i knew this solution. I would like to know has the light a special/factory problem, or not. I red that i need to make a 2,5 hole at the bottom of the cluster to solve the problem.
Italian cars have this problem so often they should list it as a feature. Alfa's and fiats even new ones on forecourts have this issue. I wouldn't worry about it. They clear up rather quickly once the light is on.
