General Rear light cluster on Sei
steviem18
My passenger side rear light cluster on my sei gets full of water! it works fine just gets very wet lol it means that when the weathers ok it gets very fogged up with condensation! Guna purchase a new one but just wondering before i buy a second hand one if this is a common fault on the sei?? don't wana buy one and it do the same??
simple cheap little cure.......... remove the light unit and drill a small 2mm hole at each end of the underside of the light unit to let the water drain out and let the air in to clear the condensation. done it on my wifes a while ago and not had a problem with it since.
when they are made in the factory are they made so that they are air tight ? if not why didnt they make little holes as standard lol
luckily ive not had a problem with mine but have heard of many a person who has
i did think of doing that sounds like a plan wouldnt hurt to try!!
Okay it's not the same but I've got a rear cluster that has a small hole in the lens and the whole cluster is permanently fogged up in winter.
does that mean if i put drainage holes in mine then it will still get fogged up??
