Technical Rear hub
Technical Rear hub
Connollyg
Andover
Hi there, i have just changed the nearside rear wheel bearing. The old one has an integrated reluctor for ABS sensing. The new one has a magnetic rubber ring. ABS light is now on. Do I need to change the sensor? Any advice gratefully received. Thanks Grant
Model
Fiat 500
Year
2008
Ideally use scan tool to read wheel speeds when moving and see if all similar/ which one not working.
Was the brown magnetic hub ring damaged when fitting? Or the abs sensor?
Did you disconnect /reconnect abs sensor while replacing hub?
