Dear Forum,
As I have seen from a lot of threads here and in other forums, there seems to be a big problem with the older Doblos rear door locks. In my particular case it is the Split version (just inherited from my father-in-law).
I did not find any solutions to my problems so I have decided to start this thread and am really looking forward to your input.
The Problem(s):
Firstly the lock chamber itself seems to be "stuck" I am not even able to enter the key fully. The way it looks to me is as if this is simply stuck due to a build up of lime-scale from bad weather (not entirely sure though). I am also assuming that the slot for the key should have a little metal cover which slides to the side when I enter the key just as it does on the side doors. In this case, I am sure that the parts are simply stuck as the slot is always "open".
The question is how I can loosen this up? Simply spraying it (lube / WD40) hasnt seemed to help. I have also not yet found out how to remove the entire handle / locking unit and am not even sure if this is going to help me.
The second problem I have is that my father-in-law had the central locking disconnected from the rear door as he was having problems with the locking mechanism itself. Of course I can only check this locking mechanism problem once I reconnect the central locking. (There are enough forum entries into fixing the locking mechanism itself). But how do I reconnect the central locking to the back doors.
Looking forward to all of your input.
Regards
Scott
The Problem(s):
Regards
Scott
