molla elicoidale
- Joined
- Mar 30, 2012
- Messages
- 6
- Points
- 1
My centre rear seatbelt is locking itself very tightly against the backrest. Even with the car on level ground, the only way to release it is to tilt the backrest forward to create some slack, remove the seat base, unbolt the belt's bottom mounting, and let it retract before pulling out.
When fully deployed, there are no signs of damage to the belt, but it appears to have been getting trapped. This is evident from a number of tight crease marks (not actually folding over) in the belt a few inches below the point where it dissapears into the seat back.
Because the inertia reel is mounted inside the seat back I can't see what's going on and the backrest doesn't have any obvious means of being dismantled.
If anyone has experience of this problem, can they tell me:
1. How to dismantle the seat back - do I have to rip off the carpet attached to the rear?
2. Can you identify another Fiat, GM or even generic inertia reel replacement.
Typically this has cropped up just a week before the MOT is due, so any early advice would be much appreciated.
