Everything seemed to go well with replacing the passenger side rear brake shoes, but I can't get the adjuster arm (I'm sure there's a better name for it) to sit properly on the adjustment gear. It's all new shoes, cylinder, pins and springs. I reused the old adjuster rod/gear and arm.
I test drove it lightly and there were no bad noises or smoke. The pedal is squishy, so I will bleed the rear brakes again. Maybe I missed some air the first time around.
Does anyone have advice on getting the adjuster arm to sit properly? Is this a catastrophic problem or just a no-big-deal? Below is a before/after photo where you can see the adjuster arm is not sitting on the gear correctly.
Thanks,
Joe
2001-ish Ducato 2.8JTD (230) RV
Thanks,
Joe
