Technical  Rear Beam Axle Alignment
South East
I know this has been covered before but...here's the story. Had four wheel laser alignment done today and was advised the rear axle is 'crabbing'. Here are the figures:
Left rear toe: -0.09 degrees
Right rear toe: +50 degrees
The technician suggested it might be possible to create some 'adjustability' by elongating the holes in the brackets through which the bolts for the rear bushes go, but I don't like that idea one bit.
I was wondering if, instead, it would be possible to insert a shim (drilled with the appropriate holes) betwen the mounting plate on the axle where it attaches to the floopan (by two bolts).
Having said all that, in five years I've had no uneven tyre wear, the car drives straight as a die and handles beautifully...so should I be bovver'd? Answers on a postcard...
Assume you mean Right rear toe: +0.50 or +0.05. Not +50 degrees. :eek:
The four bolt holes in each of the brackets that hold the axle to the floor are already elongated and would allow a small amount of adjustment.
However, if there's no abnormal tyre wear and the car's not pulling to the right, I'd leave it alone.
Putting a shim between the bracket(s) and the floor would only tilt the bracket(s) and axle vertically, not twist it horizontally.
The rear axle is designed to crab slightly to help keep the rear end tight when cornering. A simplified version would be the trucks of a skateboard.
As the axle is solid and offers no adjustment my guess would be damage caused by impact, eg potholes, or component failure, probabely bushes.
Davren, well spotted! The figures should have been:
Right rear toe: +0.50 degrees.
Shadey, could you explain what you mean by:
'The rear axle is designed to crab slightly to help keep the rear end tight when cornering'
and how this works in practice..? I'm not a skateboarder, so your illustration is lost on me!
I've just converted the Stilo eLearn rear axle page to PDF format and attached it to this post. The diagrams will explain it better than I could.
"specially developed for this model and are able to create a toe-in effect on corners to ensure excellent driving stability even under extreme conditions"
The correct alignment of the rear bushes is crucial for them and the the axle to function properly, especially when cornering.
(y)
  • stilo eLearn - Rear Axle.pdf
Having read the doc, I think I understand. It's saying the angle at which the bushes are mounted, relative to the axle, creates a toe-in effect when cornering forces are applied.
However, it still doesn't explain why my toe-in figures (at rest) are different, left to right. Unless, as you said earlier, there's been some deflection of the axle by damage (which I'm not aware of).
I hate to throw a damp squib into the post but according to ABCD the fixed static rear toe in on all Stilo models is the same left & right -
3mm +/- 2mm
0.24' +/- 0.16' } degrees
0.40 +/- 0.27 _.._
There's are reasons why its called a "Torsion Axle". One being it allows the "toe in" to vary when cornering.
ABCD?
:confused:
As the bushes are designed to help the "Toe In" effect, I wonder if installing lowering springs has twisted the bushes just enough to effect the amount of "Toe In" the axle produces prematurely and thats the reason why your getting odd 4 wheel alignment readings?
If it’s not causing a problem why worry?
The other thing that comes to mind is how good was the guy doing the tracking, there are a lot of bullsh**ers out there looking for easy money for a job that doesn’t need doing.
If it really bothers you I would suggest you at least get a second opinion from a different garage.
Re: Rear Beam Axlehttp://www.fiatforum.com/images/editor/menupop.gif Alignment
Sorry folks it should have read ' Autodata '.
I have it listed as ABCD and wrote that without thinking!
I'd always assumed that a torsion beam axle was designed to twist to allow one wheel to move vertically more than the other rather than to bend in the middle to allow toe in to vary.
Correct, but the Stilo rear axle is not a normal "Torsion Axle" as is explained in the PDF I attached to post 5.
As I said earlier, there is more than one reason. The clever design of the Stilo axle and its offset bush design does more, allowing the axle to change the "Toe In" and help keep the rear end tight when cornering.
The rear axle helps oversteering at high speed. (y) I love the skateboard image you provided, Shadeyman. Turn left or right, and the rear axle comes along to help.
