Styling really bad shut lines :(
limited edition
Weston, Somerset
i took the wing off to replace with a freshly painted one due to accident damage on the old one, now i have to find a way of setting the bonnet straight :confused: becuase i have a massive gap on the other side and no gap at all on the side i've just replaced.
Its a 2006 3door "blue" just need to know is there an easy way of doing this as the hex style bolts for the bonnet are very well buried.
Also the new wing seems to overlap the headlight :confused:
Cheers Jon
The wing is off of a later model 3 door 2nd hand so presuming its a original part. and i've managed enough wigling and adjusting the bolts to make it so it lines up with the bonnet lines but my bonnet touches it at the point where its closest to the windshield :confused:
Thanks for quick replies.
i think the wing may not be fitted quite right... id line up the bonnet with the un-moved wing, then re-adjust the wing to match, then finally fine tune the bonnet again.
long winded but the only way IMO
