S
Sven
K, I know I already did a guide on this subject and you all are getting sick of my guides about this, but bear whit me once again because this time it removed all the rattle.
Its easy and a you just need a knife.
On this pic is shown a rubber pin (or what ever you want to call it) and its designed to hold the doors down corner from moving when the door is shut.
The rubber gets ÒeatenÒ away in time, so the door can move in that part and automatic lifts this end
so the window isnt firm in place.
You just need to pull the rubber pin off whit a knife, its glued on, and turn it 180?, so the down part goes up.
Or get some rubber about 2/3 mm thick and glue it on the door, on this place. (circle under the reflector)
The second move is to put one, or one and a half turn of electric tape on the door hinge, this will then pull the door more ÒinÒ and lean the door on the rubber again.
If you dont have any rubber pin on the chassis of the car, you can make one (like me),
or you can buy one from Fiat (dont know if they stock them)
And thats it
Sven
And thats it
Sven
