Technical  rail snsor
peter-cts
help trying to find rail sensor on 1.9 jtd 2005 model so i can fit cr tuning box
instruction supplied useless
manual on cd from ebayer does not show this
thanks peter
If ypu are tallking about the fuel pressure rail sensor, then its on the fuel pressure rail, in the middle.
thanks for your reply
i have found the rail but sensor appears to be on the end
been back onto the seller still useless
has any one got picture or diagram
if any one has a wiring diagram showing wire colours this will help
thanks peter
thanks peter
hello
I've got a cr box for my 1.3 multijet... yes its the one on the end !!!... depending on the box you have you may have to remove the little yellow clip on the sensor , to fit the CR box ... be careful removing it.. and don't lose it in the engine bay... :(
Yes there is a difference in the performance when fitted... If you've got the screw type min/max setting for the power always make a note of how many screw turns you've made .... :confused:
if your really stuck i could take some photos of the fitting.. :D
Do you have more detailed information on where I can find the connector on the 1.3 engine? A picture would really be appreciated. Thanks in advance ;)
