Bravo Radio playing as if it can't find stations
Do you need help unlocking your radio?
Get your code instantly using our radio unlock service 🔓🎶
Sammi42
Hi all ... my radio is playing up . Went from being perfect radio sound to jumping on and off as if no reception on the channels. ??? fiat bravo 1.4 active sport model
Quite likely water has got into the amplified antenna base. Mine's like that. If I can see the Morborne transmitter near Peterborough, the radio is fine. If I drive down to St Neots, 20 miles away, I lose signal.
Theres a lot of work to get the roof lining down to fix it, so only do it if you plan to keep the car.
