Hi All
I have a new issue with my 2016 Panda Cross. I turned the radio on this morning (FM initially) to be greeted with a rapid tapping noise through the speakers (like a tinny machine gun) with no speech or music in the background. I ran through all FM channels and got the same noise. I switched to MW and it was the same. I then switched to MEDIA and played 5 Live through the BBC Sounds App on my phone and that worked, but I can still hear a very feint, slower tapping in the background.
I think I have the Uconnect system rather than the Blue & Me system if that makes any difference and I’ve done a search on the forum but can’t find any threads with a similar issue.
Any ideas? I there anything I should check? So far I’ve only checked that the aerial is still there (it is) and for some reason I thought I’d see if there was any signs of moisture inside the car in case there might be any water ingress somewhere causing the issue (there’s no sign of any water/moisture).
Appreciate any insight any of you might have!
