Technical Radio Cassette Code
Do you need help unlocking your radio?
Get your code instantly using our radio unlock service 🔓🎶
Looking for the code for my radio cassette. I disconnected the battery and haven't got a note of the code, so if anyone can help id be happy to make a donation to the site.
The car is a 2001,y reg punto.
There appears to be 2 numbers starting with BP, and a 'Product Nr Fiat'
BP937213816014
BP-Nr: 7 649 372 316
Product Nr Fiat: 735 272 569
Also when I turn the radio/cassette on the display says 'WAIT'. This seems to stay on display permanently
BP937213816014
Also when I turn the radio/cassette on the display says "WAIT". This seems to stay on display permanently
It says 'WAIT' because you've tried to enter (guess?) a wrong code too many times. Once you have the correct code, you need to leave the radio switched on with 'WAIT' showing until it shows "CODE" then "----". Then enter the code.
I can get the code for your radio.
https://www.fiatforum.com/donations.php
Dave.
Thanks dave,
I'd appreciate it if you could. As I said, I'd be happy to make a donation to the site if it works.
Also, have you any idea how long it takes for the 'WAIT' display to change to 'CODE' as I've had it switched on for more than an hour at one point and it remains the same.
cheers
Im sure i tried a few random codes (there were some numbers witten on the inside of the handbook) so do I just leave the radio switched on overnight? won't that flatten the battery.
I tried to make a donation using the link provided but i dont have a paypal account, is there any other way to make one?
BP937213816014
Thanks for donating to the Fiat Forum.
Your code is: 5222
To enter the code, wait till the display shows " ---- " then press preset button 5 then 2 then 2 then 2. You should not need to press any further buttons to accept the code.
Dave.
