radiator leak
radiator leak
mickyo
2005 Ducato 2.2 TD.
i have a slight rad leak and want to try radweld before buying new rad. Can anyone please tell me way to add solution. Do I put it in coolant resevoir or rad? If rad where do i add it.
Hi mate try "kseal" its brilliant for fixing head gaskets and other smaller leaks ..about £10 just pour it in and leave it in forever.
Thanks for that. Do I put it in coolant resevoir or what?
Yes mate, in the coolant res, sython some coolant out to drop level if needed then put sealant in & then topup to max mark.
Hope it seals it for you mate i put it in every car ive bought .and ive used it to seal head gaskets that have failed as well and its always worked? i used it on a 320 bmw with a frost crack on inside the cylinder and it stopped using water within a hour. and the guy drove that same car for over two years without any problem.
