Technical  quick question bout electrics
syphon123
BlackSei The Beast
Birmingham, United Kingdo
Quick question.
I gotta wire a couple of things into the ignition. So just for ease lets say its the headunit.
Can I just tap into the windows live wire, and crimp em together?
joe
Seicento Sporting 2000 X
Black
Black Front and Side Indicaters
Pioneer DCEH8400 HeadUnit + JBL speakers 6x9 in parcel shelf, 10cm in front, 10" Sub and GTO4000 AMP(600Watt).
Abarth badges all round from abarthbadges.co.uk
If its a stereo/secret piece of ICE that you don't want to say what it is :D then it might be easier and safer to run a new fused power cable from the battery
It were proper Bo i tell thee!!​
I got the power sorted, I gotta run it thru ignition tho, and while i was at it, i thought i may as weel do the stereo at the same time. sick of having to turn it off lol.
The "items" i want to run are already fused so that shouldnt be an issue.hehe
joe
Black
There's definetly something fishy going on here....
I think Syphon is working with the government to produce a one-off Cinq powered battle machine that is also invisible and has big missiles and massive machine guns and can go on water as well and has big tank wheels and..and...I think I need to go and take a nap and take my pills...
Of the 2 connector blocks on the ignition barrel, don't use the block with the thick brown and thick red wire. that block is for ignition ONLY! Balls that one up and your gonna be in big bills!
Use the block with the 4 connectors on it. you'll need to crimp a feed from the yellow/orange cable. the block should have a formation like:
### You need the connector marked red to take a safe feed from.
Hope this helps
Is adrenaline brown?
so is that an easy job to do. I wanna run my stereo through the ignition and another item
It has a permanent live wire, but also another wire for the ignition. it isnt required, but would stop battery flattening.
thanks
joe turner
Black
