Technical  Quick Engine Removal
Hutbed
Sorry for the major delay, but I've finally finished and posted my quick but complete guide video for removing the classic 500 engine. The only thing I forgot to show was disconnecting the throttle cable next to the choke cable. Hope it helps!!
Thank you for the video Andrew---very useful for the "1st time removers". One little point, if you are taking JUST the engine out, you don't need to do anything with the clutch or its adjustment. I also remove the rear cross-member separately, as I have found that it is a LOT easier to put the engine back sans the cross-member and re-fit it once the engine is all bolted up. When I worked at Radbourne Racing (many, many years ago) I also could just hump them around, even put them onto and off the work bench on my own. Sadly, anno domini has caught up with me, and whilst I can still heave them in and out on my own, I need a bit of assistance to put on/off the rotisserie. I have made a small wooden 'pad' that fits onto the top of the jack, and under the complete sump to give the engine good support whilst heaving it in/out. Notwithstanding, these comments---a good video---thank you.
