A Alex Guest Dec 12, 2007 #1 If i remove my rear seats completely will I have any problems on an MOT? Thanks
M Mark Guest Dec 12, 2007 #2 If they are not there, they cannot be tested, so will not fail an MOT... Make sure you remove the seatbelts too...
OP OP A Alex Guest Dec 12, 2007 #3 Question Ok so basically they run on the approach that they can only test what is there not what should be there (in this case), as in if i removed the seats and the seat belts, they wont say that i should have them in there. Thanks
