hi, just wondering on the turbo conversions that people do how do you sort out the cooling of the turbo? do you get an oil cooler and plumb it up and run it straight off the battery or ecu?? cheers
Tom
Tom
the punto GT or even the fiat coupe oil cooler would be ideal, I wouldn't recommend running a tubby with out it
The oil cooler cools all the oil in the engine and is connected to the pressurised oil system, usually by a sandwich plate with thermostat.
The turbo gets its oil supply from one of the spare ports on the oil pump, and the return goes into the sump.
SPD
Some of the Japanese turbos may actually be of a suitable size. I'm dreaming of a turbo off the JDM Scooby Legacy. IIRC, 2.4 litre, twin turbo, ball bearing, lots of titanium rotating components, dual entry, water cooled, very fast spool up. Like hen's teeth, though.
Effectively the water flow is constant -- it'll only affect the bearings (and the oil flowing to them). While the water cooled ones can be run dry, it's probably not a brilliant idea -- you loose the (marginal) advantages of post shutdown cooling (which won't be great as the water pump won't flow any coolant -- in some OEM fittings there are mechanisms to overcome this) for sure, but I'd guess that the bearings are actually toleranced to take the cooling into effect.
Of course, the reason you don't cool the turbo itself is because the heat energy is responsible for some of the thrust: the fashion is to actually insulate them to they stay hot.
