Technical  Qubo throttle position sensor location
Frankiequbo
Telford
Hello all.
Can anyone out there assist me with the location of the throttle position sensor please. It's a 2012 1.3 multijet.
Fiat are saying it's on the throttle body itself, but I cant for the life of me see it.
Something is telling me it's on top of the throttle pedal assembly.
Please help.
Hello all.
Please help.
I can't confirm anything here and I'm working from a 19 plate Trekking but recently when having a few codes investigated, the tech (finding the clutch position sensor was throwing a code) went to the pedal and found the sensor was floating in the air and he pushed it back along a rod (from what I could see) above the pedal so that pedal movement did whatever it needed to do with the sensor. Since then the Cruise Control has worked every time and not been intermittent which it was prior to the sensor falling off...so you may be right to look around/over the pedal area.
HTH
R-V-M
