Technical  Qubo Replacement Bumper
Kenny Rodgers
After a minor bump, I need to replace the front bumper on my 2010 Qubo Active.
Can I fit a bumper for a Fiorini, Bipper or Tepee?
There is a bumper on ebay for a Fiorini at £67 which seems ideal if it fits.
Kenny
Kenny
They all fit Bipper Tepee Fiorino Qubo, I've seen the ones on Ebay for £67, is it the one with fog light holes? or not, the fog light hole version would be ideal for the fitting of drl's.
LUIGI
Thanks for that. Much appreciated. I will order one up.
It will be the one without the holes. I assumed that the holes were for fog lamps and my Qubo doesn't have any.
Kenny
Just to let you know how I got on.
The Fiorino bumper was not as deep as the Qubo bumper by quite a margin.
Once the old bumper was removed there was a padded spacer that was not refitted with the new Fiorino bumper and it fitted fine.
the net result is a stubbier nose compared with the original which I actually prefer.
£67 was a bargain!
So passenger vehicles drive into pedestrians harder/faster than vans? More Eurocrass-stupidity I guess (n)
Paul
Its only a styling thing
Qubo's have colour coded bumpers front and rear
Fiorino's have black plastic bumpers with the silver trim on the top of the front bumper.
Bippers, nemo's have the same front bumpers as the fiorino but the panel is colour coded.
The passenger versions have slightly different design to Qubo colour coded
The 2013 onward fiorino bumper now has fog lights under headlights [makes a great way of adding DRL's] new bumpers of this type can be got for a little as £65
Pre 2013 fiorinos that had fog lights a slightly different design bumper on the lower half and the fog lights were placed on the outer edges of the bottom grill.
All bumpers from any model will fit, some adaption of the crash bar will be necessary if changing Qubo to fiorino bumper.
LUIGI
LUIGI
Thanks for the clarification!
My 'new' Qubo has the fog lights deep set low down. It's a 2012 (July) model so I guess there may have been changes since then which I had on the Fiorino but aren't on the Qubo. I haven't found anything as yet though I don't think the Qubo has an alarm as the central locking is silent(ish) and doesn't wake the neighbours so I guess it's only locking not alarming..
Ex-R-V-M ..maybe now I'm B-Q-M though in bright light the paint seems to be dark metallic anthracite not black. D-A-Q-M then ;)
Pretty sure an alarm was an option on them ,there is the facility to read alarm causes on the software.
