Hi again Scorps02....The left stalk controls the indicators, up for right, down for left, and turn it on the end for side/headlights, to dip you pull back towards you and release, and to to return to main beam again pull back toward you and release.
The right stalk is the wipers, turn on the end, 1st is delay wipe, 2nd turn 1st speed, 3rd turn high speed. The small inner ring, towards the steering wheel, turn that for the rear wiper, this comes on automatically when the wipers are turned on and you select reverse gear. Lift the stalk for flick wipe, and push down for washers.
The important bit on this stalk is the button on the end, each press of this takes you 1 step through the on-board computer readings, i.e., you average mpg, your current mpg, total mileage left in the tank, mileage covered, e.t.c.
That may sound a bit scary, but you will soon master it, it is really quite straightforward, sit in the car for half a hour and play with it, all sorted.
Any other questions please ask, however I'm away now until later in the week, so you may have to wait for my reply, though no doubt another Qubo member may reply before I do.
Enjoy the car, I never drop below 50mpg, even on the silly shopping trips, and have down well into the 60s on a run. If its a new car it will need 10.000 mile on it before it starts to perform efficiently, both in respect of pulling and mpg, so bear that in mind.
Qube O.
