Nice one Frank. As mentioned worth joining that FB group. What engine do you have? Be careful with the MA units - The Mk.3 Delta was an early user of that engine - My actuator went and took the Turbo with it for an expensive bill. Other thing to note is check your HVAC unit. The BiZone unit flap motors are prone to failure and its a dash out job to resolve. You will know you have an issue when one side is hot and one side cold. I still think the Delta 3 looks great in the right spec. All the best, Nello
I did indeed join both the facebook Delta 3 group and the Chrysler Delta section, and apart from screwing up signing in with the Chrysler group, which meant I was unable to reply to some very helpful hints from Rosso et al., for a while, all has been good, with great information and support. I have actually trawled a great deal of the info and posts (tons from your good
self) on each site before I got the car. I did pass on a good M-Air near me (it is in Thornton-Cleveleys) as it was a manual and we wanted an auto. That car was a steal. One owner family from new, present owner (grandson of buyer) emigrating - the straightest motor with genuine low (60k) miles I ever saw in my life, so I posted it on the Delta 3 forum in case somebody was interested but it has not gone yet. As it is, I was also wary of the M-Air myself, but I read that most failures were early on and dealt with on warranty. Your car experience shows even that idea is not necessarily correct though, but it was the fact it was a manual that stopped me. I got the 1.6 T-Jet auto a couple of weeks ago, but my timing is a bit screwed as I also got a total hip replacement fitted a few days later. That has put a bit of a crimp in my car activities for the moment
You are spot on with the looks of the car too. The UK motor publications and the Parkers people, who virtually all sniffily reported that the styling was of the "Marmite" variety, did us all a favour by making the car more affordable than it should be, were it not for the fools who reviewed it when the car came out. To balance that, I must admit I have owned three Ford Scorpios, so maybe my judgement on aesthetics is vulnerable to criticism too
It registered 53 mpg around town before I had my leg repaired, but I also drive like a blind granny sat on a crate of fresh eggs so that, and short shifting in front of the auto box change, helps. The car is an SE Nav with the panoramic roof and despite me being effectively grounded at the moment, I am a happy bunny. Shortly I need to do the usual - cam belt, water pump, aux belt change as I am not aware they have been done. The rest can follow in due course but best to make sure valves and pistons stay separated. And please forgive me for being nosy but I must ask - what did you get to replace the Delta? Best, Frank B
