Evening people.
Its been a while since I was here, but been a while since I had a fiat!
Have had a Mk2 Punto for 12 months or so. To be fair, has been a good little car.
Started to misfire / run crappy on an intermittent basis. Put it on a code reader and came up with P0352 (Coil pack B - I am hoping its not ECU like I have read)). Replaced coil pack and erased codes and car is running a lot better - not perfect, but expect will take a few miles for ECU to adjust to coil pack. When it was misfiring, the EML was also intermittently illuminating - would come on with the issue, start to run fine, then next time it was stared EML was off)
I have only replaced coil B - coil A was replaced in April when it got a P0300 code. (and that cleared up when replaced and codes erased)
However, since issues with misfire, (now corrected!) have noticed what I can only describe as a rattle from the left hand side of the rocker.
I know its picking straws / needle in haystack, but any ideas? My only two would be camshaft (or belt) or tappets (assuming they are fitted? - I don't know)
I hope its not too serious - I don't have a lot of money for repairs (or replacement).
I know there are various threads on here, but I am not sure if I have one issue, or several.
Oscar
Oscar
