why does a mk2 8v have 60bhp and mk1 8v have 75bhp and same litre engine.
Different cam and management.
SPD
so when it gets to 5500 power will start to drop?
so in theory best place to change would be beetween 5000 and 5500?
if you didnt mind ragging your engine
il rag 1st gear tomoro and find out lol im thinking that it will redline at about 6000 rpm anyway its only a 1.2
Will i break the engine if i redline every gear is that not what the redline is there for?
It wouldn't be best no. All you're doing is wearing the frigging engine out. The limiter is there to avoid engine damage, not to be abused. It's there as a failsafe, just because you change gear at 5k instead of hitting the limiter doesn't mean you're going easy on it. Holding any engine to the limit, like has already been said, is pointless anyway because the power tends to be made below the limiter. If you're going to drive every gear to 5500 then you're going to cause damage at some point and you've already said you aren't overly technical mechanically, so lets hope you've got money.
All this ragging your cars is fruitless on the road where you shouldn't even be driving fast. All to squeeze every last one of the 60bhp out of your puntos...? Rev it to what you want, it's never going to be very fast, might blow up spectacularly though.
at what point did i say i was going to do any of this? im just interested in the theory of it thats all
i have no desire to destroy my engine and/or drive like a ****
i dont really fancy becomeing another statistic my insurance is high enough as it is thanks
At the end of the day it all depends on what your situation is, if you're driving on track and want to get the best from an engine that can take the stresses and strains then you want to be changing gear slightly over where the power comes in. That way you get all the power and are closer to those revs again when you get the next gear, it's all about getting each one at the sweet spot. Revving it out just won't do the engine any good and you'll not be going fast as poss.
That help a bit?
I don't mean to come across so negative but someone will read this and go out and try it on public roads. We all know that, so just expressing my view on it.
Dont think revving engine to 5k is ragging it. So long as engine is warm its fine to rev to 6k in short burst. FIRE engine like somewone said likes being revved. Revving to the limmiter is ragging it. Its not dangerous, thers no law against acceletation on a straight road. It may however be anti social, you shouldnt red line your car in a built up area at night it really p**ses people off, the noise that is.
Was a time when cars only had 4 gears so youd be doing 4000rpm at 70 mph. It was then possible to damage an engine driving at 85 mph for extended periods of time. People would potter around town never driving more than 5 miles at a time then rag the car 300 miles down the motorway once a year for holidays. Remember early 70s as a young kid. Youd get a hot day in summer people driving down to devon, see loads of cars on the hard shoulder. You could break down next to someone else and have a chat about whether it was the big end or a small end .. .. .. .. . but modern cars have high fifth or sixth gears, short bursts of revs on a warm engine are fine.
Id say I probably rev to 5000 or so once or twice a week. I dont exactly count.
One caviat. If you have a turbo, not so much of a problem these days but revving a turbo hard just before you turn the engine off is as bad or worse than revving a cold engine. Something about letting it cool down slowly.
my mk1 1.2 has a rev limiter kick in at 6500 RPM, would be better if it was higher as i'm converting the car bit by bit into a rally car
Out of interest what are these bespoke systems?
Is it a generic item , who make it?
Do they replace the ECU or do you keep ECU but not manage the engine with it?
