These are KNOWN recalls. source is the AA.
N.B. Please note these recalls are over 10 years old. FIAT May not cover the recall anymore. If your vehicle has been affected and not had an issue resolved please contact FIAT for further information
Description: POSSIBLE FAILURE OF STEERING COLUMN BEARINGS
VIN: ZFA188000000299008 TO ZFA18800000359182, ZFA18800004273056 TO ZFA18800004337762, ZFA18800005090823 TO ZFA18800005112105
Build Date: 1st February 2001 to 28th May 2001
Defect: The steering column upper support bearing may be cracked. This could ultimately affect the directional control of the vehicle.
Action: Recall affected vehicles to examine the condition of the steering column bearing. Fit new steering column assembly if the bearing is found to be cracked.
Description: FUEL VAPOUR RECIRCULATION PIPE MAY BECOME DAMAGED
VIN: 51420 TO 201384 4005830 - 4182900 - 4182900 5000094 TON5055134
Build Date: August 1999 to June 2000
Defect:The fuel vapour recirculation pipe could foul against the air-conditioning compressor pulley resulting in possible damage to the pipe and the risk of fire.
Action: Recall affected vehicles and reposition recirculation pipe away from compressor pulley
IF YOUR VEHICLE IS EFFECTED;
contact your local fiat dealership. ask them to check your VIN against any outstanding Recalls, they will tell you if the issue had previously been resolved.
Manufacturer contact details:
Fiat Auto (UK) Ltd
Fiat House, 266 Bath Road, Slough, Berkshire, SL1 4HJ
(01753) 511431
Fiat Auto (UK) Ltd
(01753) 511431
