Punto (Mk2/2b) Punto Pete's HGT
Punto_Pete
CAR SPECIFICATIONS:
- Model : HGT
– Engine size : 1747cc
- Year : 2001
– Colour : Broom Yellow
ENGINE MODIFICATIONS :
- Supersprint exhaust, manifold back, inc de-cat
- Standard manifold decat-ed
- K&N induction kit
- GSR uprated variator
- Custom clutch, 220mm, uprated everything (std is 215mm)
- Lightened flywheel now 5.23kg (std 8.29kg) 37% weight loss
- Head skimmed, 0.36mm removed (due to being badly warped)
- Throttle body coolant bypass
- Throttle body gauze removed
- Big fat home-made cold-air feed to filter
- Replaced lower engine/gearbox mount and modified it to make it stiffer
STYLING MODIFICATIONS:
INTERIOR:
- Set of mats and thats about it
- Started striping interior, rear seats and ICE gone
EXTERNAL:
- De-tango'd headlights
- De-badged bonnet
- Smoothed tail-gate
- Side rub-strips removed
- Bumper rub-strips colour coded
- Door handles colour coded
- Tinted windows
CHASSIS:
- Dare V2 17" wheels painted gloss black
- Lowered on Pi springs (says 35/15mm on the box)
- Painted brake calipers
ICE:
- Kenwood KDC-7021 headunit
- Kenwood KCA-IP500 ipod adaptor
- iPod Nano 4Gb
- Standard speakers and sub
FUTURE MODS:
- Custom lower manifold section and sports cat, or Supersprint manifold
- Iridium spark plugs
- Custom stainless hardpipe for air filter, or GSR induction kit
- Up-rated dampers/coilovers
- Eibach anti-roll bars (if they'll fit)
- Upper and lower OMP strut braces
- Polybushes (again if they'll fit)
- Bucket seats and harnesses
- Finish striping interior
- Maybe stop breaking things when i boot it?!
Nice (y). the rims look slick, also like where you've put the badge, wts the bhp?
Do you know anywhere, where you can re-map a hgt?
i don't know power and torque figures yet, putting it on the dyno this weekend at the Red Dot day.
as far as i am aware no-body can genuinely map the euro2 hgt. chippeduk claim to be able to, but i have my reasons for not considering them.
i'm considering standalone management to get around the mapping problem.
oh rite, im thinking of tweeking my punto hgt, its stock at the moment, but was recommended in getting the GSR air in-take kit from here so considering that, iv got this chip or unit i should say, that you connect the wire to the ecu, and it states plus 45bhp but now i am not to sure?
what do you recommend, out of everything you've done to your hgt?
oh btw where did you get your rims from?
Where did you get that flywheel done? and which clutch are you on, im thinknig about black diamond! Any thoughts.
the flywheel was done through my mate at www.1stopperformance.co.uk. the clutch i had custom made, its a 220mm Valeo unit but everything was uprated (springs, friction materials, etc).
your 'plus 45 bhp chip', isn't an engine chip its just a resistor that will severely damage your engine. it basically puts the choke on permanently, and you wouldn't get 45 bhp from it, more like about 2 bhp, whatever you do don't fit it.
Lovely car mate... i had my 1.8 stilo remapped at chipped uk, not sure what ecu i have though! Not sure what your reasons are but im a year on now and i still get this :D everytime i plant my foot!
i believe you've got a different ecu to the Punto HGT. does your stilo have the VFD engine, ie the variable valve timing as found on the HGT and Barchetta?
Out of interest, how much did the clutch cost you? Don't worry if you don't want to say. (y)
i think i paid about £70 for the clutch. i'm lucky, the manufacturer is local, less than 1/2 mile away :)
really nice and sounds like it will shift some(y)
are the bumpers and side skirts different colours to the rest of the car??:confused:
thanks, it does seem to shift quite well ;) i'm loking forward to getting it on the dyno. and the bumpers + skirts, they've faded with age. the whole car wants a re-spray as there's some poor paint matches started showing up.
you no what i normly dont like that shape but i rely do like yours, the things uv done just look ace!
RR results as promised.
145.6bhp at 6200rpm at the wheels, 119.3bhp and 112lb/ft at 3900rpm at the wheels
i can't edit the original post, how crap is that??
here's the pics:
