Hi i have a fiat punto 1.1 sx 1994 untill recently it started on the turn of the key ,occaisionally not starting but with persausion or a gentle rock back and forth would start, now however it won't start on the key which is inconvienient to say the least as i can't stop at a garage to refuel as it won,t start again ,it will start however with a push start..when i turn the ignition on i can hear the fuel pump working the noise stops the injector warning light goes out turn the key and nothing happens ,the starter motor won't turn over at all , i have changed the starter motor over however the only one i could get was one from a 1.2 punto all though as far as i can tell the only difference is the soleniod acuator terminal (1.1 is a spade terminal,1.2 is ring terminal), yesterday i took out the battery,to check the earths to the crankcase and body they all seem fine,i have checked the battery as best i can switching on the ignition and lights to see if they stay bright for any length of time, they seem ok, also when i leave lights on and turn ignition to start they go straight out, any ideas ever gratefull in advance
Cromus
Cromus
