Hello, I come to you learned elders for advice
Here is my first problem:
About half of my dashboard warning lights do not work. When I start the car only the right cluster (check engine, temperature etc..) works. On the left cluster, the heater and fog light lamps work.
To be more specific - I have removed the power steering motor for relay replacement. This should cause the "power steering" warning light to ignite on the dashboard. This does not happen, even in test phase when starting the car.
I just bought this car very cheaply and I don't mind working on it so I am not upset. I just want to figure out how to get the lights working again. I've checked the fuses and wires (even behind the dashboard) and they look ok.
I suspect the seller did some naughty things to the electrics to hide the errors, but I didn't find any cut wires. I might try opening the instrument panel to check for desoldering.
The second problem:
I have removed the engine cooling fan for repair. I checked engine error codes with a OBD2 reader: P0115 and P0480, meaning temp sensor and fan need replacement. I cleared the codes, but they are not appearing again (but they should? The fan is disconnected and the temp sensor is the same)
tl;dr
1) Dashboard warning lights are faulty - no power steering light despite motor removed, what should I check?
2) Fan removed, temp sensor faulty - no error codes appear. Is there a problem?
Pic of my interior fuse box, what are the 3 fuses (2x5A+1x20A) near the arrow for?
The second problem:
tl;dr
