- Joined
- Aug 4, 2010
- Messages
- 176
- Points
- 161
If Fingers99 sees this Im sure he can help as he has been pretty good so far but if anyone else knows what this is please reply
so yesterday I fitted a new cam, followers and carrier box and reshimmed it all perfect. treated it like a new cam using bedding in grease and topped up all 4 compartments with fresh oil then ran it at 2000rpm for 20mins then switched off. i havent driven the car so its not been put under any loads.
Removed my rocker cover today just to recheck the valve clearances from cold and straight away I was surprised by the different oil levels in the 4 compartments of the cambox.
im sure the levels should all be the same. The car is parked on the level.
For valves 1 and 2 - loads of oil as youd expect, valves 3 and 4 a bit less, valves 5 and 6 even less and the area around valves 7 and 8 was virtually non-existent......you can see the fresh oil I had started to pour in today (I was going to do a leak down check) but the dark oil is on the bottom where it was when i removed the cover.
is this signs of a worn oil pump not getting oil to the top end - I am thinking that maybe this is what was wrecking my previous cam and wearing the followers and carrier. at 2000rpm i had the full 3 bar pressure showing and never had issues with oil pressure before hot or cold.
Or is this caused simply because Ive not driven the car and put the engine under load yet and once I do that the oil pump will do its thing? if so just seems strange that oils gone to the far left compartment furthest away from the point of entry of the oil from the supply feed. also if it got as far as that compartment why didnt it reach other the furthest compartment. why feed 1 comparment and progressively less oil to the other 3 compartments???
I have a sore head from this.....the only thing that perhaps i'm thinking it might be is simply that the buckets are worn (they arent matched to this carrier box but i checked the clearances on all 8 and couldnt get a 0.05mm feeler gauge inside any of them.
