Technical Punto Gt starting issues
Danhenderson80
Sorry lads, Wasnt sure where to post this.
I need some ideas to why my Punto Gt wont start.
Pulled the fuel rail out with injectors in, Turned the car over and they are squirting so I'd say its getting fuel.
Pulled the plugs and turned it over and they are sparking.
Tryed spraying a little petrol in the throttle body and still didnt fire.
But when i turn it over it just wont fire,Does'nt even sound like its trying to fire and just turning over.
The red injector light stays on whilst im trying to start the car
Thanks for any suddgestions.
I also only have the blue key and alarm/immobiliser fob if that makes any difference
also is this the right ht lead order?
Yes change the leads to the correct order!! That will certainly help things.
If you are getting fuel and the sparks are correct then you can narrow it down to poor compression or a weak fuel pump.
