les1466
Hi, I know I am probably not posting the correct section here but for some reason I keep getting a message saying I do-not have permission to post in the F.A.Q's section.
My question is:
I have a 65 plate Punto Grande selespeed semi automatic. Last week I started noticing a juddering while the car was changing gear, mainly from first to second and when reversing. I also noticed an oil symbol light up briefly in the speedo clock and a message appeared on the LCD display saying "transmission - check handbook". I do-not have the handbook so I took the car to a garage near me as I thought it probably needed the gearbox oil changing with the oil symbol lighting up. I payed to have this changed. The problem still occurred so I took it back to the garage and they ran it through a diagnostics machine and it shown an error message number P17444. Hydraulic circuit pressure sensor.
Does anyone know what a hydraulic circuit pressure sensor is, where it is located on the car, where I will get one from and roughly how much they are??
The garage did not seem to want to know as my car is a Fiat. They said to contact Fiat, but the likely hood that they would know what the part or the fault code will be would be practically zero!!
The car drives fine when it is in motion but feels worse after it has warmed up a running a while. I can judder quite badly when starting in first gear at lights.
Any help and recommendations for a good cheap mechanic to fix this problem in the Manchester (UK) area would be really appreciated.
Thank you.
Les
My question is:
Thank you.
Les
