ryanbooth
how much horsepower would i gain from dropping a punto 75 camshaft (866 FIRE) in my standard sei 1108 engine just cams and my induction kit
my 75 cam just bolted straight in all my clearances were fine... but thats just mine nothing is ever the same .
Hi
Even if you only just replaced the cam with an identical cam you should plexi guage the cam bearings, and check all the clearances. With a different spec cam ditto, you will probably need to replace or move shims and may find that some shims have worn so you may need to micrometer their new thicknesses to see if they can be moved.
If the engine has done 50k miles I'd lift the head grind the valves replace springs, check bore wear etc. If you want power grind the head to the interference limit.
If the compression is low you probably need new rings.
If your cake does not have candles on it your ins company may want oodles of lucar, before they will accept engine modifications.
Washing it and waxing it on Sunday mornings is cheap.
Noel
Hi Yea I did check every thing the p75 cam has stopped all the rattle from my little beast :d..did you follow the P75 clearance setting yeah ?
ming
