Technical punto 55 running badly
bar1
my punto 55 1.1 is running badly, its had new leads, plugs, rocker cover gasket, rocker cover filter,induction kit, exhaust, battery and exhaust, i,ve tried carb cleaner and it helped, but its still missing power i know its only a 1.1 but there must be something that can help, any ideas?
finaly found the answere
after making my own induction kit, i found the answere, the cam belt was heavily worn and stretched causing the timing to be slightly out, the replacement cost me £15.00 from partco and a mate fitted it cheap as chipps, i can pass on his number if wanted in the bristol area, now it runs like a dream, admitadley the induction kit helps ands sounds great, hope this helps other peeps
the punto has a carb, if you undo the two 10mm nuts on top of the air box, then remove the air box you will see a silver/ grey round hole with a wire and a shinny metal plate that opens and closes when tou use the throttle, thats called a carb,
