Technical Punto 2002 1.2 L 8V Engine Oil
PuntoGR
GR
What engine oil do you use for your Fiat Punto 8 V gas ?
These engines run very hot, do you all agree ?
I've seen 10 W40 semi syn wear down to waterish liquid within 3500 km's.
I was hoping to add 600ml to a quart of this lucas stabilizer.
Says to mix at minimum 20% of oil capacity....
It will increase oil pressure, because it is a thicker oil and help fuel economy.
It's pretty thick, I just want to quiet a tapping sound on cold startup....
