Mk 2 Punto 1.2l 8v SOHC vibrating on idle
Apologies if this has been posted before. Last night I think I clipped a pot hole (it sounded that way), since then the car has a rough idle, runs poorly and is making a metallic rattle under load.
I have:
While I was under the car I also noticed it is blowing from the exhaust at the 1st connection (between CAT / Downpipe and 1st section) and also from 2 month old back box (seam).
I obviously need to sort the exhaust leaks but would this be the cause of the issue or am I looking at HG failure?>
Any suggestions would be appreciated, thanks in advance
I have:
- Checked timing
- Checked leads
- Visually checked lifters
