Technical Punto 1.2 16v engine sound
sheik
HELLO guys,
I am having a punto 1.2 16 v 2002 model car which runs almost 1,70,000 kilometres actually i bought this car as second hand.
Car of the engine make huge noise and vibraion (not heavy) inside the car. As a reference please go through below link
youtu.be/gKVZPKkzVG4
Since that fan is screaming it means your aircon is on
When you turn the A/c off - does the noise stop?
As this will kinda indicate whats going on
If the noise stops with AC off, the clutch pulley/bearing has started to fail
if it stays the same - i'd assume its a bearing somewhere
and yes - its a little stupid putting your finger near a spinning belt
Ziggy
sounds ok to me
but my god, why put your fingers near a belt running at that speed, thats just idiotic
I am feeling vibration inside the car what could be the reason.. yEah i AM so Crazy ON that Time
Ziggy
I did not use A/C on that time. Engine is normally making that noise once its started is bearing died ?
