Project Autobianchi A112 1242 16V
Hi! I´m building a A112 racecar with 1242 16V Punto engine from 2006.
Basicly a pretty much standard 80 hp engine with 4-2-1 header an Megasquirt engine management.
The gearbox is standard A112 Abarth 5 speed with bellhausing from a Uno 999 FIRE. In that way I can use 2 out of 3 original enginemounts and standard A112 Abarth driveshafts.
Gearlinkage is standard A112 Abarth.
But, I wonder:
The engine is missing the throttlebody, but originally there is a electronic fly-by-wire item, and I need an item that is operated the old fashioned way with a wire from the throttle pedal.
Do any of you Fiat wisards know of what throttlebody to use?
Scuderia Sedicivalvole
(Sorry for bad english :)
I dont know if it helps but the Fiat Barchetta uses a cable throttle body, I think the buterfly opening is aprox 60mm..
but alternately there are loads of universal throttle bodys on ebay.
You need the throttle body from an early Brava 1.2 16v CF2 engine. About 1998-2001.
I think the fiat part No on it is: 71738374.
You might need the complete intake manifold with injectors and fuel rail.
