My Ulysse 2.0 Petrol Auto Eleganza is going in for it's 1st service in 3 weeks and I have found a few problems which I think need to be fixed. Has anybody had any of the following issues.
1. The auto gearbox whines sometimes when you decelerate. It also seems to select the wrong gear sometimes as well. When you go round a bend and slow down, the gearbox doesn't change down.
2. The climate control fans make a slight screaming noise as if the bearings are not lubricated. You can alter the noise by switching the rear fans on/off.
3. The foam on the driver seat side is collapsing, I think others have had the same problem and had the foam replaced.
4. There is a rattle from under the driver dash, under the small instrument binnacle.
If anybody has any advice for the "dealer" it may save some time when I take it in.
Andy
Andy
