Problems with front screen washer pump
A
Alexey
2008 Fiat Bravo. Front screen washer pump is not working. When I pull screen wash lever I hear no pump sound. However rear window is still working and pump sound is loud and clear.
Is there single pump for the front and rear windows or it is separate one for each?
If it is single pump, why it works for rear window only?
Please help.
if it is a single pump and your rear works,then could be a case of a simple fuse?
Its a single pump as mentioned, the problem may be in the stalk, or fuse/ wire to the pump.
Take off the connector on the pump, and using multimeter check if there is any current coming to both connectors when activated on the stalk.
Members Site ---------My Site
M
7K
M
T
1
787
Joseph
J
T
1
807
A
C
7K
ChrisKnottIns
C
I
2
1K
Dark Lurker
