probably dumb question
A
Anonymous
will water come through rear wash pipe if it has come loose?
Boot has wet patch but can't find any leaks
if the pipe has come off the rear jet then when you spray the boot lid will fill with water and no water will come out of the rear jet. Does any water come out the rear jet?
If the pipe is split you may get some out the jet and some into the car but i would expect there to be noticably less pressure
Re: Re: Re: probably dumb question
this is a common problem (just this sunday i had to put mine back on)
what it is is when the water is frozen in the pipe like it is at this time of year the pipe blows off the end of the connection, and you get no spray and a wet boot...
bravo guide will sort you out:
"No Rear Wiper Spray"
http://www.bravo-guide.co.uk/fix-a-bravo
Re: Re: Re: Re: probably dumb question
just to add... follow that guide and you can't go wrong!
let us know how you get on!
Dan
no water comes out of jet and the wiper doesn't work
Re: Re: Re: Re: Re: probably dumb question
Make sure you are using a washer additive with antifreeze :)
B
2
528
BRUNO
B
4
492
Darren
N
1
918
Ozric-Al
O
A
14
978
M
