F Fiat-Iceland New member Joined Oct 5, 2005 Messages 21 Points 8 Jan 19, 2006 #1 what are u boosting your turbo ??? and the gas ??
OP OP F Fiat-Iceland New member Joined Oct 5, 2005 Messages 21 Points 8 Jan 25, 2006 #2 when you are boosting up the turbo. how much will you boost the FSE power boost valve ??
S sumplug Established member Joined Apr 19, 2005 Messages 3,244 Points 399 Location sunny Spain Jan 26, 2006 #3 Fiat-Iceland said: when you are boosting up the turbo. how much will you boost the FSE power boost valve ?? Click to expand... FSE power boost valve should be set up on a rolling road. you cannot have to much boost to the turbo if the clutch is standard.. about 1bar max [turbo pressure] for standard healthy clutch
