A AutoCruiseK334 Member Joined Mar 1, 2026 Messages 26 Points 59 Location Northampton Mar 1, 2026 #1 Could anyone help explain the sequence to remove the power steering pump from a 1990 Fiat Ducato 2.4TD (8144.21 engine) Model AutoCruise 5ET Year 1990 Mileage 133868
OP OP A AutoCruiseK334 Member Joined Mar 1, 2026 Messages 26 Points 59 Location Northampton Mar 16, 2026 #21 jackwhoo said: Maybe Month and year code on pump Click to expand... That sounds a reasonable assumption. Thank you. Upvote 0 Downvote
J jackwhoo Distinguished member Joined Apr 8, 2017 Messages 8,977 Points 2,389 Mar 16, 2026 #22 . bugsymike said: I was thinking an O ring in a groove? It needs something as there is engine oil around the gears inside that housing it bolts too. Click to expand... Hi Mike, You are 100% correct. Fiat part number 14459380 Best wishes Jack Upvote 0 Downvote
OP OP A AutoCruiseK334 Member Joined Mar 1, 2026 Messages 26 Points 59 Location Northampton Mar 16, 2026 #23 jackwhoo said: . Hi Mike, You are 100% correct. Fiat part number 14459380 Best wishes Jack Click to expand... Thank you ALL for your responses, they have been a great help. Now to put it all back together. Upvote 0 Downvote
